Windows version of Cura - does not have “save zero” button on the extension window. no matter what i set the zero point to it digs into the surface. it worked fine before the updates.
I’m having the same problem with the new print monitor. It seems that the zero point is not being saved when hitting Print.
Regardless of position when hitting print, it always goes to the same Z (digging into bed) for the first layer (or two).
@hoodel@mattp
Thanks for the feedback.
Could you upload your studio log and Cura log via Feedback Form?
There may be other users having the same problem and we’ll check that out today.
I just uploaded the app.log (no studio log) and the Cura log.
In doing so, I noticed a config.json file under 3d printing. it has a attribute indicating the zero point. I’ll experiment with that tomorrow to see if it reflects the setting when ‘Print’ is clicked.
I did the experiment to see changes in ~/uarm/studio/3DPrinting/config.json. Indeed, when you click ‘Print’, the new z-value is written to the file { “version”: “1.0.3”, “uarmzeropoint”: 9.2 }. Still, when it goes to print, it moves to z=0 (which is just below the bed), not the set point.
