For problems, bugs and suggestions for uArm Swift (Pro), NOT your projects.
After unpacking there was no firmware installed and after installing the firmware running the firmware_helper.exe the calibration must be run. Then the arm started working fine, but only using 32bit uarm_client.exe (win7 64bit)
P.S: Plug the air hose to the proper one which sucks
Thanks for clarifying!
