Firmware Version: Latest (released yesterday, 8/1)
Operation System: Win(10)
uArm Controlling Method: uArm Studio (also latest version)
Record and play works.
But Blockly does nothing at all.
I have a very simple command (move forward 10, reset) - I’ve tried changing the value of 10 higher in case that wasn’t enough to see movement).
When I hit the “play” button to run the commands, it does nothing at all.
This is a slightly more complicated version, but also does nothing at all. I added the “on keypress” to try to trigger the commands, and the beeps so I could tell if it was doing anything. But so far, nothing at all.
Any idea what I’m doing wrong?
<xml xmlns="http://www.w3.org/1999/xhtml"><variables></variables>
<block type="set_buzzer" id="C-Wos5;*wL-mdePci,dJ" x="12" y="38">
<value name="frequency"><block type="math_number" id="C[q1*?l{)X3kesMt*AL1"><field name="NUM">1000</field></block></value>
<value name="duration"><block type="math_number" id="R:-d_%~ua.p*edZ(Ai-V"><field name="NUM">0.1</field></block></value>
</block>
<block type="event_tip_sensor" id="iag9S`)ngt1jachc-a-R" x="13" y="113">
<comment pinned="false" h="80" w="160">This command let you trigger commands by pressing the suction cup (which is also a switch) of uArm.</comment>
<statement name="statement">
<block type="set_buzzer" id="1IQIgCW4(RFJ}5Pa()HG">
<value name="frequency"><block type="math_number" id="ph+;]@xR#Mqtgoy@,0Ea"><field name="NUM">1000</field></block></value>
<value name="duration"><block type="math_number" id="|h.FJ+M_pK,r#+.!lJSl"><field name="NUM">0.1</field></block></value>
<next>
<block type="controls_flow_statements" id="uK^-tJF;4|^Fz^W0yEaX"><field name="FLOW">BREAK</field></block>
</next>
</block>
</statement>
</block>
<block type="event_keypressed" id="#:=swFz{s`tW7/.0M8CM" x="12" y="238"><field name="keycode">65</field>
<block type="set_buzzer" id="-0%_z-ANO/Gil2`512nS">
<value name="frequency"><block type="math_number" id="SzYJzdY^r_hWa0[`X7_b"><field name="NUM">1000</field></block></value>
<value name="duration"><block type="math_number" id="2jdrqFH{V*2Ng5[!!xLV"><field name="NUM">0.1</field></block></value>
<next>
<block type="set_speed" id="/DZ`G!/7[(A6,I=}[1Yi"><field name="speed">1</field>
<next>
<block type="move" id="j0N}D^IzT}#YkFr~^J7n"><field name="orientation">forward</field>
<comment pinned="false" h="80" w="160">Let uArm move relatively in absolute coordinates.</comment>
<value name="value"><block type="math_number" id="s.$x-W|]bnT+^2H}5~VD"><field name="NUM">25</field></block></value>
<next>
<block type="reset" id="vLZ]~!(NW$XhJO,~{EQ~">
<comment pinned="false" h="80" w="160">Reset uArm to its home position.</comment>
<next>
<block type="controls_whileUntil" id="]$#aWC2S6M0]GB4XYqWN">
<field name="MODE">UNTIL</field>
<value name="BOOL"><block type="logic_boolean" id="(eshAn/9IV-pcz9:.bDz"><field name="BOOL">FALSE</field></block></value>
<statement name="DO">
<block type="move" id="mSJ}Wq|y2Y)D}/S]Gu7l"><field name="orientation">down</field>
<value name="value"><block type="math_number" id="#i*;u#f27pEYPm:biXm+"><field name="NUM">10</field></block></value>
</block>
</statement>
<next>
<block type="set_pump" id="wE)@qL#GEnih:6z7aPmP"><value name="value"><block type="ON" id="W^9E(wyCNKiA!JM1N8Jd"><field name="on_off">TRUE</field></block></value>
<next>
<block type="set_speed" id="02M(?l?PTQCy:a%=p(DH"><field name="speed">1</field>
<next>
<block type="move" id="@)q0_^r/4REj9J6^{GY/">
<field name="orientation">up</field>
<value name="value"><block type="math_number" id="S3,h@Y4Av:WVPAUiJdW~"><field name="NUM">25</field></block></value></block>
</next></block></next></block></next></block></next></block></next></block></next></block></next></block></statement></block></xml>
