This is probably a hardware problem, but the blue light for the USB connection does not come on (and the switch is up for USB). It has been sitting idle for a while, the last time I used it it was working.
The arm is limp, no moters are activated.
When I press the on/off button, after a pair seconds, it beeps.
No blue light for USB and on/off light is red.
The wierd part is that the studio says it is connected, but nothing works (the arm does not respond, it is limp).
Pressing the record button, the green light comes on, but does not record any movements (play the light flashes).
The firmware is 3.2.0… Didn’t really want to upgrade to 4.2.0, because I wanted to 3d print.
The firmware update software also doesn’t connect.
Any hints?
Regards
Edward S. Blurock
From settings:
Device SwiftPro
Port Number /dev/cu.usbmodem14201
Firmware Version 3.2.0
Serial Number 508CB1675F67
Studio Information
Studio Version 1.1.18
Studio Channel prod
OS darwin x64 18.5.0
uArmCore Version 1.0.1
Studio Language en
