Firmware Version: Latest as of 13/08/2017
Operation System: Win10
uArm Controlling Method: Arduino/Python
I have an issue, not with tracking.py per-se, but the jumper connections to the breakout connector on the uArm itself. I connect the breakout connector to the 30-pin port and make sure it is aligned correctly as per the quick start, but when i hook up the jumper pins from the openMV to the breakout, it doesn’t power on.
If however I connect the jumpers to the right most pins (+5v, GND) without the breakout, the openMV powers on. I cant seem to find the correct pins for the Tx etc. in that configuration though.
I have tested the breakout female 30-pin connector and the 26 front pins for continuity and there doesn’t seem to be many connections between the female 30-pin and the 26-pin male end. possibly my breakout board has bad connections?
