Is there any recommended good camera model to mount on uArm for computer vision purposes?
Thanks,
Yi
Thanks,
Yi
Hi Yi,
When choosing a camera you should consider the following:
Mounting: Do not mount your camera on the uArm. Instead, find a way to mount it over the uArm workspace. UCS is designed for this type of setup. Generally it’s better, since the camera is in a fixed location, and thus you can know a lot more about the environment, and plan accordingly in your software. When the camera is moving the math gets more complex.
Personal recommendations:
If you want the very best: Logitec C920, It’s a great camera for computer vision. Fast framerate, resolution, FOV, and more.
Convenient package: https://www.amazon.com/ELP-Support-Android-Windows-Surveillance/dp/B00VDSBH9G
This is a great camera, you can 3D print a mount for it or just screw it into an existing mount. It has manual focus, which is perfect. It’s 30 FPS, as well. It’s a bit pricey though.
Otherwise: Any USB webcam will work. There are tons of cameras for under $20 that would work (albiet, they would have motion blur and won’t be all that great).
Nikon D5300 is a fantastic camera
No doubt Nikon has awesome cameras, although my impression is that a cheap camera should suffice.
Resolution: Get 640x480 camera. There’s no use in higher resolution, as UCS doesn’t use it, and it isn’t necessary for computer vision tasks.
I am still curious what you are building that could take advantage of nikon. @adair
This uArm project uses LifeCam Studio: Checkers Playing Robot Arm - YouTube
Features of this camera include autofocus, high frame rate, and it was mounted onto the uArm. Seems to contradict the advice above.
Which do you recommend for current use of uArm metal?
