I want to use the provided impedance control implementation but I will have to adjust the stiffness of it at runtime. Is this possible? Thank you.
Hi Michael,
It’s possible in theory, need to call set_impedance_mbk to modify it.
But we haven’t tried it yet, usually we pass a fixed value. You can try to modify parameter K, but it is not recommended to modify it too much at one time.
How do you want to modify it? We can do the test, if you have a script pleas share it with us thank you.
Hi Minna,
thank you for the fast reply!
I want to implement a simple adaption law, something like, k_t=k_0+alpha*e_t^2, where k_t is the adapted stiffness, k_0 the initial stiffness, e_t the current tracking error and alpha the adaption rate. I want to adjust the stiffness of the impedance control only within certain limits of k and with a relativ small adaption rate.
I would really appreciate if you could test this or something similar. Thank you for your help.
