Check if suction cup is holding load - xArm7
Is there a function which returns a boolean value or some sort of callback to let the user know if the suction cup is holding a load or if it failed to suck something up?
Are you talking about this feature?
Yes! In the Python SDK how is this done?
Hi,you can refer to the example below:
import sys
import time
import datetime
import threading
from xarm import version
print(‘xArm-Python-SDK Version:{}’.format(version.version))
arm = XArmAPI(‘192.168.1.135’)
arm.clean_warn()
arm.clean_error()
arm.motion_enable(True)
arm.set_mode(0)
arm.set_state(0)
time.sleep(1)
arm.set_position(*[425.9, 0.0, 678.8, 180.0, 0.0, 0.0], speed=200, mvacc=20000, radius=-1.0, wait=True)
arm.set_position(*[430.4, 0.0, 389.7, 180.0, -1.2, 0.1], speed=200, mvacc=20000, radius=-1.0,wait=True)
arm.set_suction_cup(True, False)
for i in range(int(6)):
if arm.get_suction_cup()[1] == 1:
break
time.sleep(0.5)
arm.set_servo_angle(angle=[97.8, -23.9, -93.9, 0.0, 116.1, 0.0],speed=20, mvacc=500,wait=True)
arm.set_position(*[-36.9, 344.5, 471.8, 180.0, -1.7, 97.8], speed=200,mvacc=20000, radius=-1.0, wait=True)
arm.set_suction_cup(False, False)
arm.set_position(*[425.9, 0.0, 678.8, 180.0, 0.0, 0.0], speed=200,mvacc=20000, radius=-1.0, wait=True)
else:
arm.set_servo_angle(angle=[-81.9, -23.9, -93.9, 0.0, 116.1, 0.0],speed=20, mvacc=500, wait=True)
