I'm feeling confused about the use of UCS. In some posts I've read that this tool is ONLY for uArm Metal, but in other posts people is complaining about UCS not recognizing the uArm Swift (basic or Pro) ansd the answers from uFactory is just a recommendation to forward the event to the customer technical support, when they clearly should say that UCS is not intended to be used with an uArm other than Metal...
I have a uArm Swift Pro which is not being recognized by neither the UCS nor the uArm Assistant, although it works ok with uArm Studio (latest release).
So... just to be clear... can the UCS be used with the uArm Swift Pro ? A simple yes or not will do.
If the answer is no... I'll have to further investigate why my uArm Swift Pro is not recognized.
Thanks.
