I have a inquiry regarding the robot. I want to connect the XArm 6 robot to Node red using TCP/IP but first i am required to obtain the IP from the robot. Can i use the IP of the control box, and as for the PORT number is there way to declare it inside of the blockly programming?
Can I also send the data using the IP to the nodered by adding my own code inside the XArm IDE using python?
