Dimension question
I will receive my Uarm in a few days, I already want to start working on a base.
Can somebody give me precise measurement of the base ? (see the pictures :wink: )
Hello @Boblio
the base is A=B=185mm.
If you are making a base for the robot i sujest you remove the β€œLegs” and directly screw the base of the sobot to the base you are making. the hole distance of the base is A=B=72mm
Thanks for your answer and suggestion :slight_smile:
