This is a demo script. When you move the first arm, the other arm follows.
Requirements
- Python 3.5-3.13
xarm-python-sdk
(pip install xarm-python-sdk
)- Two robotic arm of the same model (e.g., two xArm 6) on the same network.
- OS Recommendation: For best performance, it is recommended to run this script on a Linux system with a real-time patch. Running on Windows is not advised due to potential real-time performance issues.
Quick Start
- Configure IPs: Edit the script below and set
MASTER_IP
andSLAVE_IP
. - Enable Master Arm: Put the master arm in a mode where it can be moved manually (e.g., drag-and-teach).
- Run: Save the code below as a Python file (e.g.,
dual_arm_sync.py
) and run it from your terminal:python dual_arm_sync.py
- Stop: Press
Ctrl+C
in the terminal.
Full Code
import time
class XArmSyncController:
def __init__(self, master_ip, slave_ip, init_speed=10):
self.master_ip = master_ip
self.slave_ip = slave_ip
self.init_speed = init_speed
self.master_arm = None
self.slave_arm = None
self.running = False
def connect_arms(self):
try:
print(f"Connecting to master arm: {self.master_ip}")
self.master_arm = XArmAPI(self.master_ip)
self.master_arm.motion_enable(enable=True)
self.master_arm.set_mode(0)
self.master_arm.set_state(state=0)
print("Master arm connected successfully.")
print(f"Connecting to slave arm: {self.slave_ip}")
self.slave_arm = XArmAPI(self.slave_ip)
self.slave_arm.motion_enable(enable=True)
self.slave_arm.set_mode(0)
self.slave_arm.set_state(state=0)
print("Slave arm connected successfully.")
return True
except Exception as e:
print(f"Failed to connect to arms: {e}")
self.disconnect_arms()
return False
def _ensure_sync_before_follow(self, safety_threshold=0.2):
_, master_angles = self.master_arm.get_servo_angle(is_real=True)
_, slave_angles = self.slave_arm.get_servo_angle(is_real=True)
if not master_angles or not slave_angles:
print("Safety check failed: Could not get arm angles.")
return False
for i in range(len(master_angles)):
if abs(master_angles[i] - slave_angles[i]) > safety_threshold:
print("Warning: Position deviation detected. Auto-syncing...")
if self.slave_arm.mode != 0:
self.slave_arm.set_state(0)
time.sleep(0.1)
code = self.slave_arm.set_servo_angle(angle=master_angles, speed=self.init_speed, wait=True)
if code != 0:
print(f"Re-sync failed with error code: {code}")
return False
print("Re-sync completed.")
break
return True
def start_sync(self):
if not self.connect_arms():
return
if not self._ensure_sync_before_follow():
print("Final safety check failed. Aborting sync.")
return
try:
self.slave_arm.set_mode(1)
time.sleep(0.5)
print("\nSlave arm is now in follow mode. Move the master arm. Press Ctrl+C to stop.")
self.running = True
while self.running:
code, angles = self.master_arm.get_servo_angle(is_real=True)
if code == 0 and angles:
# Speed and acceleration parameters are required in servo mode
self.slave_arm.set_servo_angle_j(angles=angles, speed=100, mvacc=2000)
# Check for errors on the slave arm in real-time
if self.slave_arm.error_code != 0:
print(f"Slave arm error detected. Error code: {self.slave_arm.error_code}. Stopping sync.")
break
time.sleep(0.01)
except KeyboardInterrupt:
print("\nUser interrupted. Stopping sync control.")
print(f"\nAn error occurred during sync: {e}")
finally:
self.stop_sync()
def stop_sync(self):
print("All connections have been disconnected.")
def disconnect_arms(self):
if self.master_arm and self.master_arm.connected:
self.master_arm.disconnect()
if self.slave_arm and self.slave_arm.connected:
self.slave_arm.disconnect()
if __name__ == "__main__":
MASTER_IP = "192.168.1.xxx"
SLAVE_IP = "192.168.1.xxx"
sync_controller = XArmSyncController(MASTER_IP, SLAVE_IP, init_speed=10)
sync_controller.start_sync()
