Enable manual mode in python
I would like to activate the manual mode of my XArm 6 Lite only while pressing the space bar, if the space bar is not pressed the arm should go in the locked-in position.
I specifically want to use Python for that. What is the procedure to get there? Help would be really appreciated!
Here is an example.
  1. Install the libs with
pip install xarm-python-sdk keyboard
  1. Update with your Lite 6 IP, and running the codes.
import keyboard
# Connect to Lite 6
arm = XArmAPI('192.168.1.xxx')  # Update with your Lite 6 IP
arm.connect()
arm.motion_enable(True)
arm.set_mode(0)  # Set to motion mode
arm.set_state(0)
# Key press event: enter teach mode
def enter_teach_mode(event):
    print("Entering teach mode")
    arm.set_mode(2)  # Mode 2 is teach mode
    arm.set_state(0)
# Key release event: exit teach mode
def exit_teach_mode(event):
    print("Exiting teach mode")
    arm.set_mode(0)  # Back to motion mode
    arm.set_state(0)
# Bind space key
keyboard.on_press_key('space', enter_teach_mode)
keyboard.on_release_key('space', exit_teach_mode)
print("Press and hold SPACE to enter teach mode, release SPACE to exit.")
keyboard.wait('esc')  # Press ESC to exit the program
# Disconnect
arm.disconnect()
