I really can’t get this compiled. I’m probably doing something wrong. If you have any ideas let me know.
Arduino: 1.6.10 (Windows 10), Board: "Arduino/Genuino Uno"
In file included from D:\Documents\Arduino\libraries\uArmLibrary\src/uarm_library.h:13:0,
from D:\Documents\Arduino\libraries\UArmFirmata\src/uarm_firmata.h:44,
from D:\Documents\GitHub\beam\interactive\robots\sketch_jul26a\sketch_jul26a.ino:15:
D:\Documents\Arduino\libraries\uArmLibrary\src/UFServo.h:80:0: warning: "MAX_SERVOS" redefined
#define MAX_SERVOS (_Nbr_16timers * SERVOS_PER_TIMER)
In file included from D:\Documents\Arduino\libraries\ConfigurableFirmata\src/ConfigurableFirmata.h:18:0,
from D:\Documents\GitHub\beam\interactive\robots\sketch_jul26a\sketch_jul26a.ino:11:
D:\Documents\Arduino\libraries\ConfigurableFirmata\src/utility/Boards.h:33:0: note: this is the location of the previous definition
#define MAX_SERVOS 0
In file included from D:\Documents\GitHub\beam\interactive\robots\sketch_jul26a\sketch_jul26a.ino:16:0:
C:\Program Files (x86)\Arduino\libraries\Servo\src/Servo.h:74:0: warning: "MIN_PULSE_WIDTH" redefined
#define MIN_PULSE_WIDTH 544 // the shortest pulse sent to a servo
D:\Documents\Arduino\libraries\uArmLibrary\src/UFServo.h:74:0: note: this is the location of the previous definition
#define MIN_PULSE_WIDTH 500 // the shortest pulse sent to a servo
C:\Program Files (x86)\Arduino\libraries\Servo\src/Servo.h:75:0: warning: "MAX_PULSE_WIDTH" redefined
#define MAX_PULSE_WIDTH 2400 // the longest pulse sent to a servo
D:\Documents\Arduino\libraries\uArmLibrary\src/UFServo.h:75:0: note: this is the location of the previous definition
#define MAX_PULSE_WIDTH 2500 // the longest pulse sent to a servo
In file included from C:\Program Files (x86)\Arduino\libraries\Servo\src/Servo.h:63:0,
C:\Program Files (x86)\Arduino\libraries\Servo\src/avr/ServoTimers.h:57:16: error: redeclaration of '_timer1'
typedef enum { _timer1, _Nbr_16timers } timer16_Sequence_t;
In file included from D:\Documents\Arduino\libraries\uArmLibrary\src/UFServo.h:63:0,
from D:\Documents\Arduino\libraries\uArmLibrary\src/uarm_library.h:13,
D:\Documents\Arduino\libraries\uArmLibrary\src/ServoTimers.h:57:16: note: previous declaration 'timer16_Sequence_t _timer1'
C:\Program Files (x86)\Arduino\libraries\Servo\src/avr/ServoTimers.h:57:25: error: redeclaration of '_Nbr_16timers'
D:\Documents\Arduino\libraries\uArmLibrary\src/ServoTimers.h:57:25: note: previous declaration 'timer16_Sequence_t _Nbr_16timers'
C:\Program Files (x86)\Arduino\libraries\Servo\src/avr/ServoTimers.h:57:41: error: conflicting declaration 'typedef enum timer16_Sequence_t timer16_Sequence_t'
D:\Documents\Arduino\libraries\uArmLibrary\src/ServoTimers.h:57:41: note: previous declaration as 'typedef enum timer16_Sequence_t timer16_Sequence_t'
C:\Program Files (x86)\Arduino\libraries\Servo\src/Servo.h:87:3: error: conflicting declaration 'typedef struct ServoPin_t ServoPin_t'
} ServoPin_t ;
D:\Documents\Arduino\libraries\uArmLibrary\src/UFServo.h:87:3: note: previous declaration as 'typedef struct ServoPin_t ServoPin_t'
} ServoPin_t ;
C:\Program Files (x86)\Arduino\libraries\Servo\src/Servo.h:92:3: error: conflicting declaration 'typedef struct servo_t servo_t'
} servo_t;
D:\Documents\Arduino\libraries\uArmLibrary\src/UFServo.h:92:3: note: previous declaration as 'typedef struct servo_t servo_t'
} servo_t;
C:\Program Files (x86)\Arduino\libraries\Servo\src/Servo.h:94:7: error: redefinition of 'class Servo'
class Servo
D:\Documents\Arduino\libraries\uArmLibrary\src/UFServo.h:94:7: error: previous definition of 'class Servo'
class Servo
Thanks!
