uArm Serial No.: (the No. at the bottom of each uArm reading “UARM-04021700CC”)
Firmware Version: latest as of 20 august 2018
Operation System: Win10
uArm Controlling Method: uArm Studio 1.1.17
Hi there
I want to use the Grove gesture sensor block in blocky with a Grove Gesture V1.0 which is connected to my uArm Swift (non Pro) on the I2C port on the side of the robot base.
But i can’t get it to work in uArm studio. It seems to generate no input. I have verified that the Gesture sensor works on a Arduino board.
My arm is a non Pro version. uArm swift. FW is v2.3.6.
Shouldn’t i be able to connect the Grove gesture sensor to the plug on the base of my non-Pro uArm swift??
In uArm Studio i get the message “Pin: Gesture not detected. Gesture Sensor”. I can confirm that the gesture sensor gets its 5V supply voltage through the Grove plug.
