I solve this with the following code (Python):
swift.set_position(240, 0, 30, speed = 20000, wait = True)
r = 30
while r > -5:
r = r - 1
swift.set_position(z = r, speed = 2000, wait = True)
if swift.get_limit_switch():
swift.set_pump(True)
break
swift.flush_cmd()
Greetings Klaus
Any way of making this a smooth movement down to the switch?
My arm moves very jittery as it does these small increments one-by-one. I would like to see if there is a way to optimise this for better speed.
Hi, matt,
you can also try these: Bring the arm at your standard speed to a safe height above your object. Try the following code:
r = startingheight
while not swift.get_limit_switch():
r = r - 1
#r = r - 2
#r = r - 3
#r = r - 4
swift.set_position(z = r)
swift.set_pump(True) #False
swift.set_position(z = startingheight)
r is the starting height. Try to change the factor (r-1) until you have a good result.
Greetings Klaus
