uArm Serial No.: UARM0505170732
Firmware Version: 3.1.18
Operation System: Mac
Problem #1 was flashing the firmware. This latest uArmStudio version did not work. When I tried to update the firmware, I saw a “USB Disconnected” message and then no progress at all. The firmware didn’t flash.
However, jumping around that first problem was not enough. My arm is still broken.
So on to Problem #2 - Whenever I try to start the laser process, the arm will respond while setting the 0 position, but after that is set and I click continue, nothing happens. The arm does not move. The laser does not activate, and the UI never advances from 0%.
Actually, now it looks like just going to the laser/draw option in the software crashes the whole app. So that’s lovely.
At least in the previous version I could burn a few things. This current version is unusable
Are there any updates on this issue? Unfortunately other tasks have taken my time so I haven’t been able to personally just go check recently. Thanks for your work.
Laser seems to be working all right at least for me. Tried a few SVG files successfully yesterday. There is already a p4 however. What did that add @Cleo ?
It fixed a bug of drawing (while drawing with p3, the end-effector mistakenly changes to the laser mode). So if you want to draw as well as engrave, please use p4. Sorry for the confusion.
