Hi folks,
we just bought a Lite 6 which has an 8-pin end-effector socket. We’d like to attach a camera which draws a max of 0.5A at 5V. Do any of the pins connect directly through from the analog connector on the base? Could we use those for 5V and control signals?
Also i can’t find anything in the manual about the USB-C connector on the base, can we use this, is there any documentation?
Many thanks, Pete.
(picture - left: 2 connectors on the base, right: end-effector socket pinout)
You can use 24V, but need to connect a step-down module to reduce the voltage to 5V.
The USB-C is only for internal use, thanks for your understanding.
Hi Minna,
thanks, i know we can use a DC to DC converter, was just hoping there was a couple of wires going to the end-effector that connect directly to a socket on the base rather than going through an opamp or logic.
I’m guessing the answer is no?
