I have been working on some code to be able to use the stepper motor from the extruder and suction cup on a project.
My first question is how can I get the stepper motor to turn using serial commands?
I tried sending the E command over serial and was met with an E22 Unreachable error.
Also, is there a way to override the safety feature that prevents the stepper motor from turning without reaching a set temperature? Right now I am bypassing this by having the extruder attached as well as the suction cup and setting the temperature to room temperature. Ideally I would prefer not to have the extruder connected at all.
