Not able to run appimage of curaforuarm on linux
Firmware Version:
Operation System: Linux (fedora)
while installing curaforuarm(downloaded from ufactory official page) it gives segmentation fault and does not run.
[DEBUG] 2020-09-21 13:56:44 [UArmSwiftPlugin.py:_on_engine_created:111]:
[DEBUG] 2020-09-21 13:56:44 [UArmSwiftPlugin.py:_on_engine_created:112]: =========engine created============
2020-09-21 13:56:44,413 - DEBUG - UM3NetworkPrinting.DiscoverUM3Action._createAdditionalComponentsView [134]: Creating additional ui components for UM3.
./bin//cura.sh: line 11:  3165 Segmentation fault      (core dumped) cura $
Hello, you can refer to the video about the use and download of the cura : https://drive.google.com/file/d/1HPYttddx1XHtm8iegCFRFrMGjF9yoeW5/view?usp=sharing
Hey, I already did everything mentioned in the video but my original question was it crashes after I run it.
Hello, the firmware version of the uarm is 3.2.0?
Yes it is. I don’t think it’s firmware issue. The cura for uarm seems to be not running on fedora.
We recommend that you can use the cura in the Windows/Mac system. Because the compatibility between uarm studio(cura )and Linux system is not very good.
Thanks.
