OpenMV does not upgrade's camera firmware
uArm Serial No.: UARM-05051704C5
Firmware Version: latest, just upgraded
Operation System: MacOS Sierra 10.12.5
uArm Controlling Method: uArm Studio 1.1.13-c2
OpenMV IDE 1.6.0
Hi.
When I connect the cam provided with the uArm Pro and follow the connection instructions, when I try step 2, to upgrade the firmware version, a window appears saying that it’s connecting, but it never finishes. OpenMv says the firmware is out of date and should be updated.
If I try to run the “tracking.py” software on OpenMV, the program runs, but I can see no images
What can I do?
Thanks in advance.
DAM
Please have a check here, you may find the answer.
Hi. This other topic seems a bit more advanced. I can’t even update the firmware…
If you can’t upload the code to openmv, it’s mainly caused by the firmware of openmv (ver.2.4.1). So please reflash the firmware and then try to upload the firmware again. It should work. THANKS
Hi. Can you tell me where to find the instructions to perform this.
Thank you.
BTW, I use: uArm Pro
Firmware Version: 3.1.16
Operation System: MacOS Sierra 10.12.6 (recently updated)
uArm Controlling Method: uArm Studio 1.1.13-p2
Actually we have already reported the issue to openmv. And they would fix this problem in next release. If you are not in a hurry, please be patient. Or you could reflash the firmware like the picture below, then follow the step 4 in instructions again.
