Problem uploading to board to the U arm with arduino
I can’t to upload Standard sketch to the U Arm
The verify procedure looks good but the upload didn’t work and “problem with uploading to board” appeared .
I’d copied the error message (below) could you help me
Arduino: 1.6.8 (Mac OS X), Board: “Arduino/Genuino Uno”
Sketch uses 14,342 bytes (44%) of program storage space. Maximum is 32,256 bytes.
Global variables use 581 bytes (28%) of dynamic memory, leaving 1,467 bytes for local variables. Maximum is 2,048 bytes.
avrdude: ser_open(): can’t open device “COM1”: No such file or directory
ioctl(“TIOCMGET”): Inappropriate ioctl for device
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
Invalid library found in /Users/mgoldzak/Documents/Arduino/libraries/examples: /Users/mgoldzak/Documents/Arduino/libraries/examples
Invalid library found in /Users/mgoldzak/Documents/Arduino/libraries/NewPing.h: /Users/mgoldzak/Documents/Arduino/libraries/NewPing.h
Invalid library found in /Users/mgoldzak/Documents/Arduino/libraries/uArm_Client.app: /Users/mgoldzak/Documents/Arduino/libraries/uArm_Client.app
This report would have more information with
“Show verbose output during compilation”
option enabled in File → Preferences.
Have you downloaded the FTDI driver from this website? It is needed for the uArm’s connection to work.
http://www.ftdichip.com/Drivers/VCP.htm
If that page looks new to you, installing the FTDI driver will probably address your issue. :slight_smile:
