Python API set_position problems
uArm Serial No.: (UARM-0505170790)
Firmware Version: 3.2.0
Operation System: Linux (Raspbian for Raspberry Pi3)
uArm Controlling Method: Python (Please specify the software/library version)
We are having issues with our uArm Swift Pro not executing certain commands. Specifically, the set_position method is not responding as expected. For example in our script, we specify particular coordinates for the robot to move to. However, some of these commands are ignored and not executed for no apparent reason. Is there a known problem with the python API that we should be aware of?
Below is our script:
#!/usr/bin/env python3
import sys, os, logging
from position import Position
from config import Conf
from time import sleep
from uf.wrapper.swift_api import SwiftAPI
from uf.utils.log import *
#logging.basicConfig(stream=sys.stderr, level=logging.DEBUG)
conf = Conf()
class Robot(object):
“”“docstring for Robot”“”
def __init__(self,filter=None):
    super(Robot, self).__init__()
    logging.debug('\tsetup self.swift ...')
    if filter is not None:
        #self.swift = SwiftAPI(dev_port = '/dev/ttyACM0')
        #self.swift = SwiftAPI(filters = {'hwid': 'USB VID:PID=2341:0042'})
        #self.swift = SwiftAPI() # default by filters: {'hwid': 'USB VID:PID=2341:0042'}
    else:
    logging.debug('\tsleep 2 sec ...')
    sleep(2)
    logging.debug('\tdevice info: ')
    logging.debug(self.swift.get_device_info())
    # Set to the inital resting position
    logging.debug('\INITAL POS Robot(%d,%d,%d) Speed %d timeout %d'%(conf.I('robot','restX'), 0, conf.I('robot','restZ'),conf.I('robot','speed'),conf.I('robot','timeout')))
    if True != self.swift.set_position(conf.I('robot','restX'), 0, conf.I('robot','restZ'), speed = conf.I('robot','speed'), timeout = conf.I('robot','timeout')):
        logging.debug("Set position failed!")
    self.swift.flush_cmd()
    sleep(1)
def move(self,start,end):
    #Up
    self.movUp()
    z =self.swift.get_position()[2]
    #Start Position
    logging.debug('\tSTART POS Board(%d,%d) Robot(%d:,%d)'%(start.getXBoard(),start.getYBoard(),start.getX(),start.getY()))
    if True != self.swift.set_position(start.getX(), start.getY(), z,speed = conf.I('robot','speed'), wait = True):
    sleep(1)
    #DOWN
    self.movDown()
    #Grip Peice
    self.swift.set_gripper(True)
    sleep(1)
    #UP
    self.movUp()
    #End Posistion
    logging.debug('\tEND POS Board(%d,%d) robot(%d:,%d)'%(end.getXBoard(),end.getYBoard(),end.getX(),end.getY()))
    if True != self.swift.set_position(end.getX(), end.getY(),z,speed = conf.I('robot','speed'), wait = True):
    #self.swift.get_position()
    sleep(1)
    #DOWN
    self.movDown()
    #Release
    self.swift.set_gripper(False)
    sleep(1)
    #Up
    self.movUp()
    #RETURN TO RESTING
    logging.debug("\treset")
    if True != self.swift.set_position(conf.I('robot','restX'), 0, conf.I('robot','restZ'),speed = conf.I('robot','speed')):
def movUp(self):
    zUP = conf.I('offsets','maxHeight')
    #zHalf = z/2
    x =self.swift.get_position()[0]
    y = self.swift.get_position()[1]
    zStart = self.swift.get_position()[2]
    logging.debug('\tUP z=%d'%zUP)
    for z in range(int(zStart), zUP, 10):
        #logging.debug("\tSet position")
        if True != self.swift.set_position(x,y,z,speed = conf.I('robot','speed'), wait = True):
    #Check if going halfway helps the robot run
    # if zHalf > self.swift.get_position()[2]:
    #     logging.debug('\tUP.5 z=%d'%zHalf)
    #     if True != self.swift.set_position(x,y,zHalf,speed = conf.I('robot','speed'), wait = True):
    #         logging.debug("Set position failed!")
    #     self.swift.flush_cmd()
    # logging.debug('\tUP z=%d'%z)
    # Make sure we did not end on an offset
    # if True != self.swift.set_position(x,y,zUP,speed = conf.I('robot','speed'), wait = True):
    logging.debug('\t\tReported Position:'+str(self.swift.get_position()))
    sleep(1)
def movDown(self):
    z = conf.I('offsets','minHeight')
    logging.debug('\tDOWN z=%d'%z)
    #logging.debug('\t\tx'+str(self.swift.get_position()[0]))
    #self.swift.set_position(z = 100)
    if True != self.swift.set_position(x,y,z, speed = conf.I('robot','speed'), wait = True):
    sleep(1)
English
Could you past the log as well?
