Can anyone explain the how they solve the rotation angles of right/ left motor using inverse kinematic of parallel-mechanism robot? Thanks so much.
Hi, Zejiang
This is joey from uArm team. Actually the left servo and right servo are separated rather than parallel to each other. Each servo controls the rotation of one link independently.
So, uArm is a serial robot which has 4 servos at each joint. You can use geometry solution to solve the inverse kinematics. Anyway, we have the latest APIs which includes the inverse kinematics function (calXYZ(x,y,z)) inside. You can check developer.evol.net for more information.
Regards,
Joey
Algorithm engineer
I want to make a Uarm but with different size.
For the inverse Kinematics, what constant do I have to change in the firmeware ?
Just this two (exept for min max limits) ?
#define ARM_A 148 // upper arm
#define ARM_B 160 // lower arm
What do mean the 2 constants offsetL, offsetR ?
Where do you confirgure them ?
The lenght of lever of left servo is not taken in account in the setPosition routine. Why ?
Thnaks for your answers
Sorry, I meaned right servo, not left.
