Roll Pitch Yaw calculation problem on xARM 6
At my school of engineering, we have 5 xARM-6 robots with 1.8.10 firmware and Studio. For my next robotics classes, I’m developing forward kinematic model on Matlab.
I’ve noticed some problem on Roll Pitch Yaw calculation on xARM Studio (I’m using web browser to control the arm).
Results (see below my post) for 2 robot’s configurations (TCP offset are 0 and BASE too) :
TEST A => q0 is ZERO POSITION
TEST B => q10 is J1 = 10° and the others are set to 0°.
My FKM position XYZ is the same as the xARM studio for both tests.
PROBLEM on RPY:
TEST A : RPY is [ 180 0 0 ] for xARM studio and my FKM
TEST B
* RPY is [ 179.3 15.7 0 ] for xARM studio
* RPY is [ 180 0 10 ] for my FKM
As J1 is on BASE Z axis, I don’t understand why Ry is not 0 on your controller ?
TCP XY plan is parallel to BASE XY one.
TEST A
xARM studio :
q0 = [ 0 0 0 0 0 0 ]
X0 = [ 207.0000 0 112.0000 180.0000 0 0]
My FKM :
Tmgd0 =
1.0000         0           0     207.0000
     0   -1.0000           0         0
     0           0   -1.0000     112.0000
     0           0           0         1.0000
TEST B
xARM studio :
q10 = [ 10 0 0 0 0 0 ]
X10 = [ 203.9 35.9 112 179.3 15.7 0 ]
X10 = [ 203.8552 35.9452 112.0000 180.0000 0 10.0000 ]
Tmgd10 =
0.9848    0.1736      0          203.8552
0.1736   -0.9848      0            35.9452
0            0              0             1.0000
I’ve found the problem :grinning:
The robot configuration have been set to Angle-Axis by default (maybe after uploading the firmware).
Rx Ry Rz on the xARM studio did not warm me as Roll is around x…
Angle-Axis is vector + 1 angle => Rot(U, a) => ( [Ux Uy Uz] & a ) or ( [Ux Uy] & a ) if U is unit vector.
For my information, how to read Rx Ry Rz on the xARM studio ?
Are you using spherical coordinates for U (2 angles only as lenght of U is 1) ?
Going further on my coding.
Hi Olivier,
We set Angle-axis by default in the newer xArmStudio version.
You can switch it to RPY via ‘xArmStudio-Settings-Advanced-Assistive Features-Orientation Control’.
OK
Can you explain how to read rx ry rz on the GUI for angle-axis setup ?
Hi Olivier,
It will show the RX RY RZ in xArmStuio-Live Control interface.
Regarding SDK, please use get_position_aa.
