Hi guys, I tried the Android uArm play, but I am not able to connect to the uArm Swift Pro. I can see them in the Bluetooth list of the phone (Samsung Galaxy S8+) but not in the app’s device list. Have tried to pair using the devices Bluetooth menu, but the arm rejects the pairing request.
Any thoughts on how to make it working?
[update/solution] SamWiseTheG found that manually editing the permissions makes the app work as intended. This will likely be corrected in the future so no manual steps are needed.
I am experiencing the same issue on 2 different android devices Bluetooth is showing up in settings but not in the uarm app. Also cannot connect directly from android device
Perfect, that did the trick! So only fix uArm team needs to do is to make the permissions be required rather than just declared, and the whole thing should work fine without tweaks.
