I am trying to use uARM with ROS. I have installed the libraries as instructed.
But when I run the following command
rosrun uarm uarm_core.py connect /dev/ttyUSB0
The terminal keep showing ‘Connecting’ and I can’t continue. Is there any solution for it? Thanks.
The only additional information I can provide is that the last time I heard from Joey Song (lead developer), they were hard at work on some extensions to the firmware for ROS.
Quick questions if you don’t mind: can uArmForROS be used for features other than the control and monitor nodes in RViZ? such as writing and running scripting trajectories through ROS?
Do you have any knowledge of the additional firmware for ROS that is currently being worked on?
