I have 2 uArm swift pro, tried to use uArm Studio both on Mac an Windows, and they are not recognized… I can’t do anything. They are connected, with USB, and recognized as an arduino 2560 on Windows 7, and as nothing on Mac… any suggestions?
This is in order to update the firmware of one of my uArms, as i tried to upload the SwitfProforArduino library, and I encounter some movement problems… not as soft as the second one… jerky…
I have the same issue, 2 new uArm Swift Pro’s, both don’t move and are recognized as Arduino Mega 2560 on windows 10. Did you find any solution? I have the feeling it might have installed the wrong driver?
Specially the line “No power connected” sounds bad? Also is it ok that it writes all this stuff about being a 3d printer, while I don’t even have that kit and haven’t told it to be a 3d printer?
[solved]
uFactory has helped me solve the problem. The arm didn’t get enough power because I was using an adapter piece to convert the plug to a european powerplug. When I replaced the black cable with one that already has the european plug on it, the arm started working
I think your team got many error cases about connection-problems. Some cases are resolved and other cases are not. So, if you can share some resolved cases, it can be helpful to users. I think that many users are developers or engineers. So, users can try with suggested ways and feedback about that …
