max75
September 28, 2017, 11:55am
1
Firmware Version: 3.1.16
Operation System: Win(7,8,9,10)/Mac/Linux : w10
Update 3.1.17 won’t apply.
Still says that the firmware version is 3.1.16 and Temp prob is not fixed.
Thx.
Jean
max75
September 29, 2017, 7:00am
2
update of uarm studio was done but the update still fails
fandy_G
September 29, 2017, 11:26am
3
me too. update of uarm studio was done but the update still fails
Likewise… 3.1.17 goes through the motions, but still says 3.1.16 afterwards…
max75
September 29, 2017, 6:53pm
5
The firmware hex file is now there
and I managed to do the firmware update with the flash tool here
https://github.com/altjz/flashtool/releases
and that did fix the temp issue
Cleo
September 30, 2017, 1:47am
6
Hi @max75 @fandy_G @anthonyw
We reproduced the problem and are now fixing it.
Will let you know when it’s resolved ASAP.
Sorry for the inconvenience.
Cleo
Cleo
September 30, 2017, 10:22am
7
The problem is solved. Please update firmware again. Thanks.
FeKo
October 5, 2017, 7:20pm
8
I had the same issue, for me it worked switching back to an older uArm Studio version and updating the uArm FW before updating the uArmStudio
Same problem, I updated to the new firmware and the arm will not move.
Very troubling. Seems like V17 of firmware is not comparable.
How do I fix this?
Thanks you…
It won’t let me update. Wht do I do?
max75
October 7, 2017, 12:20pm
11
The address for the hex file is a 404.
Now it stops at 34% Flash and then times out.
What next?
R
It does not seem to be solved. Would you pleae provide steps to correct the issue?
Thank you.
Richard
max75
October 7, 2017, 8:58pm
15
Sorry but its the same problem. When I use the “Flash tool”, it gets to 34 percent and then times out.
Finally got it to update with he V17 hex file but the arm still will not move. It shows that its connected, but will not execute and moves. Very frustrating.
Cleo
October 9, 2017, 2:25am
18
@Richard_Siderits @FeKo
So sorry for the problem. Please send me these two files:
Go to Menu bar - Help - “Troubleshooting”, click download report and give me the report.
Go to Menu bar - help- Open home folder, compress the whole “log” folder and send it to me.
I’ll PM you my email. Thanks so much.
@max75
Did you update successfully in Studio?
