Last night I installed a 5.5w laser module onto the swift pro. It’s glorious! Can t run below 98% speed or I burn through 2mm ply wood. Easy install 2 solder connections and its great may have to change the zero point but offsetting manually for now… very happy.
Nice! Which module did you use, where did you get it from, and how did you attach it?
Pics would be nice as well!
Generic cheap 12v module from China up to 5.5w is doable. Simply desolder the connection from the laser to the small break out board that plugs into the arm. Solder new laser wires here. Mounting bracket swap and done. See quick start guide. Page 10. Swap red for red black for back. Easy. Have fun
