uArm Controlling Method: uClient/Cura/uArm Swift Pro print monitor
uArm successfully made a few 3D prints. Now it stops before the print is finished. Sometimes it locks up. Sometimes it just drops the extruder into the print. In all cases, Cura print monitor extension cannot talk to the arm, unless the arm is restarted (power cycle).
I was running Beta uClient/Cura. Downloaded released software, no help.
I attempted Firmware upgrade to Version 316. uClient says success, but still 315.
The problem persists.
I suspect overheating electronics. I see no means of ventilation.
Question: Is the board a standard Arduino Mega? Can I replace it?
Itās a problem of the latest Studio-1.1.13p1, weāre fixing it now.
Please flash firmware(3.1.16-dev) manually according to this FAQ.
And try again.
Thanks. Sorry for the trouble.
Btw, the board is based on Arduino Mega 2560 but modified by the uArm Team.
Please check if the Bluetooth button is up (the button beside the power). If itās down and connected by the other BT device, it will stop. And please check the connection of hot end to make sure itās well connected. Drops might be caused by the temp error.
The mother board in the arm is designed based on mega, and integrated 4 stepper drivers.
There is no error message in the Printer Monitor window.
That said, I just upgraded to 1.0.4. The print head does not drag through the previously printed plastic like it did with 1.0.3. My test print isnāt finished yet, but is is progressing beyond where the uArm stopped when I was running 1.0.3.
I spoke too soon. Before my print finished, the arm went limp and dropped the hot nozzle into the piece. I have to leave for work now, but Iāll check the screen and log file when I get back.
I also was having this problem. I updated studio and cura to the newest builds. Ran a project, worked great for 4 hours, then with about 30 minutes left in the program did the exact same thing described. I am not using bluetooth. The uarm studio indicated that the arm was not connected when I went to look at the program. Cura showed no errors.
All of the logs just show regular commands with no change. The log just stops until several hours later when I discovered the machine had stopped and closed everything down to clean up.
I had been running with the default 4mm/sec print speed. I increased it to 8mm/sec this evening, and now I seem to be getting better behavior. The piece I want to print has a 2" x 10" base. The printer would print a 2" line and a 10" line (@ 4mm/sec) and stop every time, even when cold. Changing to 8mm/sec got me past that blocker⦠until I ran out of filiment. I have more on order.
I uploaded (or tried to upload) 3 log files: app.log; curaforuarm.log and uArmCore.log. Not knowing if it is a software problem, or hardware issue, I clicked others. I couldnāt tell if it took all three logs.
The temperature in the room is variable: 70 - 80F ( 21 - 27C). It was on the warmer side when initially reporting. It is cooler now, and the problem persists.
[20170811 addendum - I just recalibrated, which improved Z-position accuracy.
Print still failed early in the first layer. Ambient air is about 78F (25C). I just posted clean log files.]
Maybe the cause is not temperature [in all cases]. The experiment Iām running suggests a different root cause.
The machine I was using had 4GB of RAM. I have hooked up a different machine with the same OS, but 16GB or RAM. The ambient temperature is 81F (~27C), and after 2 hours, the print has not halted.
I suspect the culprit might have been Garbage Collection kicking in on the small machine, interrupting communications. Iāll provide an addendum when the print completes, successfully or not.
[ 2017-08-13T12:15:-- Addendum: 20 hours into an 81 hour (est) job, and it is still printing. It is looking like there was something about the smaller (memory) computer that the uArm didnāt like. ]
[ 2017-08-15T12:08:-- Addendum: My print ran to completion, and I have started another one without mishap.
Pass: OS X 10.10.5, 2.5 GHz Intel Core i5, 16 GB
Fail: OS X 10.12.6, 2.66 GHz Intel Core 2 Duo, 4 GB ]
