hi Matthew!
i linked my standard tools for milling (should be good for lasering as well) here:
so far i got the arm moving but not in the expected way. probably because I screwed up the gcode export.
the gcode sender though, works great! It would be nice to collect some workflows (half working as well as working ones) in the tread above.
what plugin are you using in inkscape and what configuration of the plugin?
