Continuing the discussion from Swift Pro keep skipping gear around point A, laser engraving position cannot repeat (solved):
Not sure if this problem has been solved by anyone, but when engraving, the first pass will work but a second pass ends up 1cm out of alignment from the first. Successive 3rd and 4th passes follow the exact (within tolerance) path of the 2nd pass.
Is there a way to ensure that the first and second passes stay in the same position?
