Got it yesterday, overall quality is impressive!
just one major problem. I have no idea is it my unit is faulty or it’s my mistake.
When the arm head is moving closer to the base around point A, the arm is obviously skipping gear a few times and therefore making the laser engraving image failed/distorted.
As far as I understand the arm should be capable of moving the arm back to the body no problem, the range A to C should be the optimal/accurate range instead of physical limit range?
It is not 100% repeatable and I dare not to keep trying it fear the damage, but it did repeat 2 times already in 30min run on multiple laser engraving session.
on a related note/problem, when I start the laser engraving session, and then repeat the exact same session withing touching anything, the laser engraving session can be misaligned for over 1CM. in both X and Y plane.
Firmware and software are the lastest on windows 10 64bit. Let me know if any more detail is needed, thanks!
