Vadim_Z
1
Hi, two questions regarding the tool interface:
- Which API call can be used to send and receive data on the tool RS485 channel ?
- Seems there is a typo in the manual, one of the cables should be 485 B (now they are both marked A). Which one is A and which one is B ?
if you look at the python API you see it uses modbus-rtu
xArm-Python-SDK/gripper.py at master · xArm-Developer/xArm-Python-SDK · GitHub and you can use it like this
ret1 = self.arm_cmd.gripper_modbus_r16s(0x0801, 1)
for reding the first 16 bit value
