Hi
I am really not sure what I need to do here: I have connected thexArm to my laptop as specified in the manual… It cannot find the server when I press “Search”. It is now always stuck looking for “192.168.1.xxx”
I’ve looked up on Google trying to figure out what to do in the first step but I do not understand? I need to change the IP address of my computer?
“Search the IP address of the Robotic Arm
Open the xArm Studio application, click 【Search Server】 , find
the IP address of the controller, select it, and click Connect. Note: 1. The default IP address of the controller is 192.168.1.xxx. To communicate successfully with the controller, you must set
the IP address of your computer to the same network segment
and disable the proxy server.”
Joanne
