Error code S20 - Driver IC Hardware Error
We have two xArm 6 arms, for each of these arms, one of the servos has stopped working.
(The system does not let me upload two images, but the error for the second arm is identical, just on joint 3).
We tried:
  • Resetting the arm
  • Re-Enabling the arm
  • Unlocking the joint and trying to reposition it
  • Updating the firmware
  • Testing with a different controller
  • Testing different debugging commands
But to no avail - We fear it might be a hardware issue with the servo controller IC?
Any help will be greatly appreciated.
We will happily provide all necessary debugging information to resolve this issue.
If you can hop on a call we can also debug this together.
Thanks!
Hi Roy,
Please enter ‘Settings-General-Debugging Tools-Joint’, enter ‘D11’ and send, take a screenshot of the result to me.
This is from our second arm (for the purposes of this discussion, I will refer to it as “Arm B”).
This is the output from Arm A (You can see the first joint is showing code 20).
Hi Roy,
We received your email as well, it is most likely a hardware issue, let’s proceed and discuss this by email directly.
